Ортопантомограф OP100 D - Форум медтехников
nchranДата: Пятница, 12.Апр.2019, 10:01 | Сообщение # 1
Chernogolovka
Аппарат выдаёт ошибку Er 43. Чтобы это значило и чем можно помочь? Куда можно обратиться?
Rauf70Дата: Пятница, 12.Апр.2019, 11:03 | Сообщение # 2
У вас сообщений: 56
ученик
хабаровск
Обратитесь в KaVo.
МастерБакуДата: Пятница, 12.Апр.2019, 13:54 | Сообщение # 3
nchran, 89524446365 Сергей
Alex70ttДата: Пятница, 12.Апр.2019, 15:07 | Сообщение # 4
У вас сообщений: 524
рентген техник
вся Россия
NOTE
Problem: “ Er 43 *** “ error message is displayed.
“***” is a number.
Why? Wrong line voltage selection. Approximate
measured line voltage (***) is shown in time
display.
How is it detected? CPU monitors the line voltage switch signal
“MAINS” from Power SupplyBoard. Switch
is in incorrect position. This error is generated
during
power
up sequence
if
the
line
voltage (derived from the +25V supply) is
under 160 volts for 230V selection or over
160 volts for 110V selection.
When the unit is connected to 230V line with 110V settings, fuses normally
blow before this error is displayed.
Possible cause: Check or test: Parts related:
Line voltage switch in
wrong position.
Incorrect position of
110/230 switch may
cause serious damage
to the electrical circuits.
Filament Control
Board not operating,
or not connected to
CPU Board (signal
MAFRQ).
Check all four
switches in Power
Supply Board: they
must be switched to
the same position, left
or right, depending on
the nominal line voltage:
110
Vac:
S1-S4
turned
left
230 Vac:
S1-S4
turned
right
If the replacement of
Power Supply Board
did not help, replace
the CPU Board.
Check the wiring.
Replace the board.
Power Supply Board
1 CPU sets maximum mA reference.
2 CPU activates PREH signal to connect mA reference to the V/F-
converter.
3 CPU measures the frequency coming from the V/F-converter. If the
frequency is not high enough, Er 44 FIL is displayed.
