DocUReader 2 - Форум медтехников
DocUReader 2
scratch2010Дата: Пятница, 27.Мар.2015, 16:56 | Сообщение # 1
У вас сообщений: 566
волгоград
Есть у кого то сервисная документация по DocUReader 2? На аппарате сбалась калибровка сенсорного экрана. Нажимаю в одном месте реагирует в другом. Есть ли какая возможность откалибровать его?
worskДата: Понедельник, 30.Мар.2015, 07:42 | Сообщение # 2
У вас сообщений: 91
левша
Острова Питкэрн
Ухань
Прикрепил выдержку их мануала - про калибровку экрана
PergA28
worskДата: Понедельник, 30.Мар.2015, 07:43 | Сообщение # 3
У вас сообщений: 91
левша
Острова Питкэрн
Ухань
3.4.5 Calibrating the Touch screen
The Touch screen display is made of glass. Do not touch the screen
if the glass is cracked or shattered. Glass screens are sensitive to drops
and mechanical shocks.
The Touch screen of the device is correctly calibrated in the factory, but
you may want to recalibrate the display at least once a year. If you notice
that the Touch screen is not responding or does not respond accurately,
complete the following steps to calibrate it:
1
Switch on or restart the device.
2
While the device is booting, wait for the progress bar at the bottom of
the screen to turn green. When it does, keep gently pressing down on
the Touch screen until the yellow screen calibration alert screen appears.
Do not use your finger to calibrate the Touch screen. Use a pointing 
device or a pen.
Do not use a pointing device that could damage the Touch screen
such as the tip of a pencil or the extended tip of a ballpoint pen.
3
Wait for the actual black screen calibration screen to appear. Tap
the display at the intersection of the crosshairs that appear in the
corners and the center of the screen with your pointing device. Try to
tap the display as close to the intersections as possible; this practice
ensures the best possible alignment between the Touch screen coordi-nates and the LCD screen behind it.
PergA28
